Trying to replace intergrated fridge with ice box
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Trying to replace intergrated fridge with ice box
  • #89237
    MissMnd
    Hi there,
    The intergrated fridge I had just died after 10 years (not bad hey?! 😉 ) the problem is I know need to replace it but I wasn’t the one who had it fitted at the time so don’t know the brand although I think it is a diplomat ( I bought parts from ukwhitegoods before I think it was diplomat) anyway I have taken some measures and would like your advise on the replacement fridge I found , I’d like to make sure it will fit in properly so there is enough ventilation space and if it’s any good?
    So actual measures are as follow :
    Space: H 890 x W 695 xD 585
    Current fridge: 60 x 80
    Replacement fridge size:
    H 875 x W 540 x D 549
    AEG sks58840s2
    Maybe there are some other fridge out there that would be good? I’m opened to suggestion.
    The only requirements is that it has a ice box compartment.
    Thanks for your help.
    #440767
    don
    Re: Trying to replace intergrated fridge with ice box
    There isn’t much out there in column fridges with ice boxes. All the usual suspects like Hotpoint, Bosch Indesit and Siemens produce one.
    The AEG you mention is as good as anything else out there. The best one available will be the Liebherr, however it does come at a price.
    Don
    #440768
    MissMnd
    Hi!
    Forgot to mention it was a built-under fridge (with ice box)
    #440769
    don
    Hang on a minute……….
    The measurements you gave and the AEG sks58840s2 is a column fridge which is designed to go into a housing unit not under the worktop.
    If indeed it’s built under the worktop you are looking for then you need something like this Bosch. To adjust the height the legs unscrew which then allows the plinth to fit.
    HTH
    Don
