tub repair
  • #35880
    waters
    The epoxy kit is no longer available from Qualtex,they now only have the quick steel.Does anyone know where the epoxy can be obtained
    #248503
    Re: tub repair
    Araldite is epoxy though I’ve never used it for tub repairs. I tend to cut off a non essential bit of the plastic to use as filler material which I weld on with the soldering iron. I then cover the area with a thick layer of silicone sealer.
    #248504
    Re: tub repair
    have a look in your local halfords ,lots of good glues in there, 😯
    canufixit
    #248505
    robbra
    Re: tub repair
    I always use “leak fix” from Bostick…Plastic and metal, never had a failure
    Rob
    #248506
    Madmac
    Re: tub repair
    Milliput, a 2 part repair putty is what i’ve used for many years. have only seen it in model shops though. Cheap at around £3.
    #248507
    waters
    Re: tub repair
    Milliput looks exactly the same,can you tell me where to get it,thanks
    #248508
    Madmac
    Re: tub repair
    Well i’ve really only managed to find it in my local model aircraft shop.. could be a bit of a journey for you though 🙂
    http://www.sportsandmodelshop.co.uk 01349 862346. He does do mail order, helpful guy too. Im sure somebody must do it in your area though 😉
    #248509
    Re: tub repair
    Granvilles PetroPutty – available from any motor factors.
    smartin
    Re: tub repair
    or wrigleys 49p available at most corner shops 😀 me trusty gas soldering iron is great for most small jobs just dont breath in the fumes from the tub lol
    #248511
    Re: tub repair
    I once had a putty plug jump out of the hole it was plugging. Even though it was a small hole at the top of the (plastic) drum, water leaked out and got into the motor. Since then I have used bits of old plastic drum lined with silicone/instant gasket/debor and bolted in position with stainless bolts. Or grommets with debor for very small holes.
    Having read this thread though I think I’ll pop out and get myself a mini gas soldering iron (and a breathing mask).
    Mike.
    #248512
    waters
    Re: tub repair
    I will try to get Milliput,it sounds same as qualtex.It makes plastic stronger than original.Used it loads of times on washers and would not dare repair a drum and then sell a machine on.
