Tumble Dryer advice needed – reduced depth?
Home Forums Public Support Forums Buying Advice Tumble Dryer advice needed – reduced depth?
  • #57395
    stanherbert
    I’m looking for a vented tumble dryer which isn’t as deep as the usual ‘full size’ machines but still has a reasonable payload (ie: 5 or 6 kg).
    We have a cupboard which would be ideal to house a tumble dryer as it has power and a handy 4″ hole to the outside following the removal of a boiler. However, ideally the tumble dryer would only be around 45cm deep to fit.
    It can be full height and full width (ie: 60 cm).
    I notice candy make a full load, shallow depth washing machine at 40cm but don’t seem to make a matching tumble dryer.
    Has anyone got any suggestions?
    Thanks,
    StanHerbert.
    #331000
    don
    Re: Tumble Dryer advice needed – reduced depth?
    Hi SH
    There is this Zanussi 5.4 kg condenser dryer, which is the only slim depth I know of. Otherwise you are looking at one of the compact 3kg vented ones like the White Knight 38AW vented dryer.
    HTH 🙂
    Don
    #331001
    gandh1
    white knight aw44 are shallowest full capacity vented at 535mm deep not inc vents
    #331002
    stanherbert
    Thanks for the info guys. I think I’ll have to go for a full size condenser dryer in a different cupboard.
    Thanks again. Stan.
