tumble dryer AEG Lavatherm T59870 – 916096618 – assembling diffuser pushbutton start
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum tumble dryer AEG Lavatherm T59870 – 916096618 – assembling diffuser pushbutton start
  • #96532
    Haramo
    Dear
    After the print plate is been repaired by a electronical guy, I know need to assembla the control panel back and put all in place.
    Only thing is that I forget to make a picture of the diffuser, which is a small plastique item. Although when I was dissasemble the tumble dryer, I believe this item was already not in his place.
    Now I’m thing maybe the print plate had no issues at all, but only this diffuser that was not at the correct place. the issue was that the tumble dryer did not turn on, no leds flashing , nothing. All basic tested: power outlet working, tryiing to waith before connecting back the tumble dryer to the wall outlet, trying to reset .
    But it was dead.
    So I hope some can confirm if I have put the diffuser in his place? see pictures. I do have to say it’s not really fixed, I can easily take it out..; . i just hope it will not jump out of it while tumble dryer is running.. to have back the same issue.. .
    I tried to find a thread explaining which url can be attached or which size of jpg, but nothing found. I even compressed a jpg to 77kb still an error that it’s 400kb? mm.
    see here the dropbox link https://www.dropbox.com/s/6kml9iydj6jl3nf/IMG_7512.JPG?dl=0
    #463734
    cant see anything wrong with that
    Haramo
    OK thanks, so the diffuser should not be firm in the possition? I will try to put al back, hope the diffuser will not fall out of the start button.
    #463736
    when you clip it back together it holds the diffuser
    Haramo
    Dear
    After putting the panel back, the power button did not function anhmore.
    So I took a second change and then to discover that this diffuser is just the led light thing? so see photo how it was simply put and this should be done before I but all back ..
    came cleare while assembling.. 🙂
    Thanks anyway for you effort. hope this can help others too.
    https://www.dropbox.com/s/24n5br9o1lplnt9/IMG_7524.JPG?dl=0
    #463738
    Haramo
    Finally finished assembling the tumble dryer and is working again. The repair of the print plate solved the issue ( tumble dryer dead).
