Home › Forums › General Trade Forum › Tumble Dryer Leaflet
- This topic has 1 reply, 2 voices, and was last updated 17 years, 7 months ago by
maltheviking.
August 14, 2008 at 7:22 pm #38760
maltheviking
ParticipantI have produced the following information notice sheet that I thought might be good to give to my customers. I got a bit sick of the odd customer saying you were only here a few weeks ago for the same fault, then having to argue the toss with them that they have caused it to happen again through lack of maintenance 🙁
Have a read and feel free to add to or comment 🙂
Tumble Dryer no heat problems
Tumble dryers are protected against going on fire by thermal fuses and thermostats, these are not failsafe and should not be relied upon totally.
They can fail through various reasons usually through operators not following the manufacturers user instructions and maintenance. Here is a list of known basic reasons although not extensive.
User not cleaning filters every time the dryer is used (most common)
Over loading the dryer with to many clothes, this restricts airflow.
User cutting short the programme, dryers MUST complete the last ten minutes cool down period.
Fabric conditioner tissues and small items of clothing (hanky’s etc.) blocking airways. If tissues are used then it is good practice to “safety pin” them to items of clothing. Several machine manufacturers advise against using them altogether.
Air intakes on the outside of the dryer being blocked by foreign bodies (plastic bags, clothing etc) often down the back of the appliance.
Children, interfering with the machine.
Electrical power failures.
These reasons affect all dryers but there are additional issues with
Condenser dryers.Water collection container not being emptied after every time the dryer is used.
Condenser unit (canister with metal slats) not being cleaned at least one a month. (Run water through them taking care not to damage any sponge seals, either outside or in a sink) Not in the appliance
Seals, around the door, condenser unit and filter damaged. (Usually noticed by air blowing out of the sides of the door, although a slight draft is not uncommon)
All internal airways need to be kept clean. If the door has an airway inside it can be cleaned with the vacuum cleaner and a wire coat hanger.
Please read the manufacturers handbook as well as this guide.
It cannot be emphasized enough that dryers should be kept clean and not become a fire risk. Following these simple checks will give the dryer an extended life and peace of mind.August 15, 2008 at 8:33 pm #259921nomadPaul
ParticipantYou forgot kinked vent hoses 🙂
