Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › TUMBLE DRYER ON THE BLINK ! HELP PLEASE ??
- This topic has 7 replies, 5 voices, and was last updated 19 years, 2 months ago by
ginger.
January 26, 2007 at 3:38 pm #24526
ginger
ParticipantHI
WE HAVE A TUMBLE DRYER THAT APPEARS TO BE ON THE BLINK !
WHEN CLOSING THE DOOR IT MAKES THE NOISE AS IF ITS WORKING BUT THE DRUM REMAINS STILL ??
HELP I AM LOST WITHOUT IT !
January 26, 2007 at 4:37 pm #202395Johnnyboy
ParticipantRe: TUMBLE DRYER ON THE BLINK ! HELP PLEASE ??
sounds like a capacitor problem, open the door and spin the drum while the drum is moving close the door, it should continue to move. If that happens you need to replace the capacitor. Call an engineer as there are different sizes and it is important to fit the right one
January 26, 2007 at 4:53 pm #202396iadom
ModeratorRe: TUMBLE DRYER ON THE BLINK ! HELP PLEASE ??
I have deleted your other post, please keep it to one post per subject, it gets very messy if you post the same question in two forums at the same time.
It could be the belt, or the capacitor. You would have to remove the top after you have isolated the machine from the mains to check if the belt is still around the drum or not. Fitting belts to dryers is not the easiest thing in the world though.
January 26, 2007 at 4:56 pm #202397ginger
Johnnyboy wrote:sounds like a capacitor problem, open the door and spin the drum while the drum is moving close the door, it should continue to move. If that happens you need to replace the capacitor. Call an engineer as there are different sizes and it is important to fit the right one
thanks for that i have tried to spin it manually then shut the door and then it does nothing !!!!!January 26, 2007 at 4:57 pm #202398ginger
iadom wrote:I have deleted your other post, please keep it to one post per subject, it gets very messy if you post the same question in two forums at the same time.
hi yes thanks for that i did it after i realised there was a specific forum for tumble driers – as you can see i only visit this site prob once a year so not very up to date with its workings !! sorry – i will try taking it to bits tonight -!!! thanks again
January 26, 2007 at 5:02 pm #202399ginger
can you recommend an enginger for my area in doncaster ??? that wont rip me off !!
thanks tina
January 26, 2007 at 8:24 pm #202400Penguin45
Use the Repairs@ link below for a UKW engineer in your area.
January 26, 2007 at 9:27 pm #202401gegsy
ginger wrote:can you recommend an enginger
Was that intentional 😆
