Tumble Dryer to be placed in an outside shed
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Tumble Dryer to be placed in an outside shed
  • #80155
    prichards
    Due a baby on the way I need to purchase a tumble drier but due to space restrictions it will need to be placed in the outside garden shed.
    Can anyone recommend what type to buy or even a particular model.
    Thanks for any advice.
    Pete
    #411908
    Re: Tumble Dryer to be placed in an outside shed
    A vented dryer your only option in a well ventilated shed that has a constant year round temperature above 10 degrees C. If the temperate drops below that the electronics will fail big time. Avoid any possibility of condensation. Install a smoke detector, ensure the power supply is RCD protected and keep combustible/flammable items well clear!
    #411909
    don
    In addition to Martin’s excellent advice 🙂 buy one which only has timed drying like the White Knight WK44A7W. Machines with sensors won’t work unless the temperature is higher than about 12 degrees C.
    HTH 🙂
    Don
