Home › Forums › Public Support Forums › Buying Advice › Tumbledryer (in cupboard)
- This topic has 5 replies, 4 voices, and was last updated 7 years, 2 months ago by
phander.
January 15, 2019 at 11:54 am #95307
phander
ParticipantI’m looking to buy a tumbledryer that will be installed inside a kitchen cupboard.
I’m aware of the need for ventilation/air if the machine is condensing (or heatpump).
However the dryer will also be against an outside wall so I could duct out from a vented machine.All the tech points to heat pump machines being the way forward – and I’d like to be able to use the machine without worrying about running costs. (Tho’ I appreciate these machines are more expensive in the first place). So my questions:
1) Installing in a cupboard – am I simply better off going for a vented machine to reduce heat/condensation issues? Running the machine with the door open isn’t really an option…
2) If I use a vented machine, can it go out at a low level? The machine will stand on the floor.
3) Any recommendations of any particular machines?NB: Managed to avoid a tumbledryer in life until now so lack experience of them.
January 15, 2019 at 12:42 pm #459971kwatt
KeymasterAll about heat pump dryers here:
Are Heat Pump Dryers Worth It?
In a cupboard, very ill-advised.
In fact, I’d not recommend any dryer is used in a cupboard for various reasons but a heat pump or condenser one, most certainly not in my opinion. And I believe why may be covered in this article:
Tumble Dryer Installation Requirements
January 15, 2019 at 12:42 pm #459972electrofix
Moderatorbe aware of the fact you might void you warranty if the manufacturer does not like how its installed
can you consider using an integrated machine which is meant to be installed this way ?
January 15, 2019 at 7:48 pm #459973iadom
ModeratorAs regards question #2. The vent hose should always go through the wall as low as is possible, it should never be routed up and out as this will allow the hose to fill with condensation and wet fluff.
January 17, 2019 at 9:13 pm #459974phander
ParticipantThanks all.
WHat about vented machines in cupboards? I could put some kind of ventilation on the front of the door – ie so air could get in.
Will look into integrated but the choice is so limited… In fact it’s worse than that. Baumatic, Candy etc… These are not names which inspire confidence with high heat appliances.
January 17, 2019 at 9:27 pm #459975electrofix
Moderatorthe white knight crosslee dryer is commonly used in integrated situations and appear under different brands
