turbidity sensor schematic
Home Forums Public Support Forums Help And Support Dishwasher Help Forum turbidity sensor schematic
  • #91688
    Motorhomer
    Hi I have a Whirlpool ADG5010 A++ dishwasher which has a 6 terminal turbidity sensor. I would like to test this sensor but to do so I need a schematic of the circuit. Does any one have one or can they tell me what pin is what. I have found one diagram on the web but not sure if this is correct, I have attached this.
    Any help would be great, thanks.
    #448993
    Re: turbidity sensor schematic
    there is very little info on the wiring of this or how it works
    there are also 8 machines with the same model and another 2 with ix on the end so have only checked 1 at random
    on the wiring page for the timer i get this. if it helps
    but why do you need to check it in the fIrst place ?
    Motorhomer
    Thanks electorfix, This seems similar to what I have seen, I just need to work out the orientation of the sensor so i get the correct pins.
    i am doing a project to run the dishwasher from an Arduino, programming the arduino myself, I have managed to get it to fill, flush and wash incorporating the divertor and I have pause button, door switch sensor etc:
    But i still have two things I don’t fully know how they work. The turbidity sensor is one i would like to get to use, and the salt flush, I still dont fully understand hos to get the salt box to flush the softener out on the final flush
