Every time we switch the oven on, there is a loud almost grinding sound, not sure If it’s the fan, or bearings,
The noise is unbearable, and then suddenly stops, probably when the oven has become quite hot.
Yes checked the fan,
Strange turned it on just now, loud noise as usual, left it on for 10 minutes to heat up, turned off, then straight on, no noise.
I’m assuming the bearings are hot, so no noise?
if you want to prove it , take motor off. add a drop of light oil ( not wd 40 as it stinks ) and then see if noise is there from cold. if no order a new motor as the oils wont last
