tvf760 dryer
  • #56183
    wilf
    been to this machine totally dead no display nothing. everything meters ok but the heater plate thermistor seems rather high at 96+ k (dont know what it should be) I’m thinking board. as it has a connectot port does this board come blank? does the display board give trouble? anyone any ideas?
    wilf
    #326479
    timdowning
    Re: tvf760 dryer
    When you say it meters ok, is that the thermostats? As an open circuit stat can give you this fault.
    #326480
    wilf
    Re: tvf760 dryer
    this is electronic control with thermistors I’ve ordered a kit to try
    wilf
    #326481
    timdowning
    Re: tvf760 dryer
    I’ve not seen this model before, so was just guessing really.
    What does the temperature safety on these newer models?
    #326482
    helo_75
    well… the safety cut out cuts off the neutral supply to the pcb, rendering it dead
    depends on variant though
