Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › UHS53X Grill
- This topic has 8 replies, 3 voices, and was last updated 8 years, 2 months ago by
rolf.
January 17, 2018 at 4:15 pm #93090
rolf
ParticipantHi any pointers appreciated. Got a Hotpoint built under oven UHS53X. When you select grill fan comes on but no neon and no power to the grill element. If you select top oven on a different control the element comes on.
I’ve changed the energy regulator but still the same 😳 so I’m thinking there’s a possible stat causing it, but would of thought the top oven wouldn’t work if that’s the case.
large toc in center Closed circuit small toc by the fan open circuit at room temp.
Please help!!!!!!!!January 17, 2018 at 4:32 pm #453207electrofix
ModeratorRe: UHS53X Grill
have you looked at the function switch on the top oven control ?
January 17, 2018 at 4:35 pm #453208alster
ParticipantRe: UHS53X Grill
Looks like there’s a microswitch on the grill door. I would check that Al
January 17, 2018 at 5:11 pm #453209rolf
Hi Alster, thanks for your advice. I noticed on the parts list there is a grill/door switch but when I went out to the oven there is no visible switch on the top oven/Grill. There is one on the bottom oven.
Am I missing something. ThanksJanuary 17, 2018 at 5:15 pm #453210rolf
Hi Dave had a quick look but didn’t pay much attention to it. Is there something I should of been looking at.
January 17, 2018 at 6:12 pm #453211electrofix
since it uses the same elements. that switch changes them over from oven to grill so your looking for contacts that are either burnt out or just don’t quite make it. There will prob be a wire from that switch to live in on the grill regulator. if so check that contact first
January 17, 2018 at 6:58 pm #453212rolf
Emmm food for thought. I did have a quick look over the contacts and there was nothing obvious burnt out but I guess it could be something more subtle. I’m going to try and get back out there and have another gander.
Thank you for your advice Dave.January 31, 2018 at 6:01 pm #453213rolf
Ten points to Dave. New selector sorted it. 😀
Thanks a lot. Really appreciate all your help.
:tup:January 31, 2018 at 10:48 pm #453214electrofix
no probs m8
glad u sorted it
