UK Bosch wff2000 Prewash light flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum UK Bosch wff2000 Prewash light flashing
  • #10645
    I have a customer who bought their W/m over to NZ, going fine at home but 6 weeks on a container didnt agree with it When it faults the timer advances to the end of the cycle and flashes the prewash light once (according to the customer). Have checked it over, cleared the pressure chamber at the back of the drum and checked the tube, heats ok, but it doesnt fault at the same place every time, and as always when you turn up it goes fine.
    Any help would be great 😀
    #141262
    clivejameson
    Re: UK Bosch wff2000 Prewash light flashing
    First thing to check is an open circuit solenoid (cold prolly)….testing with a megger through the coil will sometimes force an iffy coil into submission, then have a look at the brushes for wear (or possibly sticking after storage in a maritime atmosphere 😉
    Failing that then its a hunt for the usual loose connections after a long transportation i’m afraid
    #141263
    Pump is worn and needs replacing (impellor too much lateral movement and sticks intermittently then programme defaults with Prewash light flashing)
    #141264
    it happened to us first we used the manual 💡 found out £1.03 was blocking the pump then it happened again nothing was blocking the pump but we needed to put 2 litres of water in the machine an spin cycle 7 then guess what it works again the next morning prewash light is flashing 😡
    #141265
    random wrote:calm downit happened to us first we used the manual 💡 found out £1.03 was blocking the pump then it happened again nothing was blocking the pump but we needed to put 2 litres of water in the machine an spin cycle 7 then guess what it works again the next morning prewash light is flashing 😡
    calm down get a new washer
    #141266
    8) 💡 the pump will be blocked ➡ 💡 8) 8) 8)
    the expert is cool
    #141267
    Just thought I would but in as I have a bosch wf2000 – have you tried turning the wash selection button to the “X” mark then start as normal the machine will then go through all cycles with no water and the pre wash light should then stop
