Hi unable to unscrew the cap to check the fluff trap on a Bosch wfo2464. Is it possible to bypass this from underneath it cheers for any help on this matter. 🙂
Often if it won’t unscrew you have something trapped in it. If that model doesn’t have a solid base you will be able to remove tube that connects the tub to the pump and remove the offending article. If it does have a solid base you may be able to get to it by removing the front plinth.
