Re: Under Guarantee
What’s this all about…Alfie 😆
This is the first time we’ve had this particular problem. There should be no need to remove the ball in the sump hose.
Just as a matter of interest how was the waste pipe connected ?
was it connected to a spout on the U bend or trap of a sink ?
Was it pushed down a waste stand pipe, if so was the end pushed into the U bend at the bottom.
The ISE machine does not have a traditional type pressure switch, in so much that it works on frequency not directly from air pressure so it may be neccessary to replace the ball in the sump hose to prevent other spurious faults from developing.
Could you give me a ring tomorrow on 07971590040 please, so that we can get to the bottom of this fault.
Sean Delaney ISE Tech Help
