Freezer stopped freezing.
Read your sticky then took off the rear panel & fan shroud in th e freezer & ithe evaporator was well iced up.
Hairdryered it clear , waited 12 hours & reassembled.
15 hours later checked tto see if had refrozen & all ok, just a little frost..reassembled. 2 weeks later its moderately frosted but holding resonable temps on some days.Here are pics of it today, approx 2 weeks after defrosting –
The freezer is averaging -12 ( empty ) now & i guess thats not enough hence im writin here now..
Other clues are the button in the fridge that i guess varies fridge temp has no effect as all the green led’s are lit. When i first defrosted it i could use this button to change the amount of lights lit but after several hours, its stuck on max.
ALL ADVICE WELCOME ( YOU LOT ARE A BIT QUIET NO ? 😆 )
Martin.
