unmarked fridge/freezer freezer door needed
Home Forums Public Support Forums Spare Parts Help unmarked fridge/freezer freezer door needed
  • #31352
    jmiddy
    hi. i’ve got an unmarked fridge/freezer, prob from mfi or somewhere. the handle has broken on the freezer door. so i need either the part or a replacement door if it doesn’t come seperatley.
    the manual is a generic one for larder / fridge / freezer / etc. i assume you need the model number for the fridge. there’s 3 – APM6121 / 6125 / 6115 or for the freezer – APM 6222 / 6403 sorry i don’t know what relates to which unit.
    if you can let me know if the parts are available that would be great thanks.
    #230865
    Dales-Electronic
    Re: unmarked fridge/freezer freezer door needed
    Can you either give us the serial number or be more specific as to what you want. The APM6222 is a built in freezer which does not have a door handle. The APM6121 is a built in fridge also without a door handle. Do you want the bit that fits to the door trim or do you want an ice box door handle ??
    #230866
    jmiddy
    ah, see what you mean. i guess it’s a handle for the ice box i’m looking for. it’s basically a strip of plastic about 2 inches long.
    sorry, don’t know where to find the serial number and can’t take the unit out of its space i’m afraid.
    hope this helps a bit.
    thanks
    #230867
    Dales-Electronic
    Need the serial number there are two versions – should be in the salad draw area and start with a 9 or 2 dependent on manufacture date.
    #230868
    jmiddy
    hi again. thanks for the pointer. the model no. is indeed APM6121
    the serial no. is 20041704006 – 030103006 – 03 – 01
    and i believe i need an ice box handle.
    thanks for your help.
    #230869
    Dales-Electronic
    Part numbers are – Complete door is 720097500, door handle is 322030500, door handle spring 444010800. Available from Shop@ to your left. Hope that helps
