UP IN SMOKE!! SIEMANS SIWAMAT 21050
Home Forums Public Support Forums Help And Support Washing Machine Help Forum UP IN SMOKE!! SIEMANS SIWAMAT 21050
Viewing 1 post (of 1 total)
  • #15228
    hairymon
    Greetings all, would appreciate any thoughts on this one.
    Had noticed increased noise recently on spin cycle but other day seemed to be spinning for an unusually long time and then smoke started to come out of it. Shut it down and when I opened the door the smoke seemed to be coming from inside the drum??? , powered off and opened it up to investigate (day after) but cannot trace anything jamming or obviously loose, however following advice from another thread i had read (on broken drum leg I think) checked for lateral play and there is a small discernable difference when I pull the drum in line with one of the legs. Would this have been likely to have caused my lightly smoked undergarments?
    Also Mrs Hairy Mon decided to press on regardless and has since done another wash but on a lower spin speed ..spin still noisy but undies have escaped unsmoked!
