Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › UPDATE: Problems with Hotpoint Aquarius 1200 WD62 Gets Stuck
- This topic has 18 replies, 4 voices, and was last updated 17 years, 4 months ago by
benmc.
November 23, 2008 at 5:28 pm #41255
benmc
ParticipantAll
Looks for some advice here on a Hotppint WD62 that is not working.
The Washer Dryer is in a house we rent out.
Got a all from the tenant say the machine is not working properly.
When you put it on a wash it runs OK for a while and then gets to a certain point and sounds like the machine is either pumping the water in or out (I guess out because the machine is not overfilling) It carries on doing this, the program dial does not move and the drum stays still.
Someone please help. I have left the tennant without a washing machine and need to fix this for them quickly.
Any help appriciated
BenNovember 23, 2008 at 7:06 pm #269278iadom
ModeratorRe: Problems with Hotpoint Aquarius 1200 WD62 – Gets Stuck
If the machine is set directly to spin does the drum revolve and go into spin?
If it does not then there is a good chance the motor brushes have failed.
If the machine washes fine until the first rinse then just sits there with water running in and out at the same time then almost certainly the plumbing is at fault.
The machine will be stuck syphoning. Can be caused by the outlet pipe being to low or being pushed right down into a standpipe. It should be at least 22 inches above the floor and if the outlet hose goes into a standpipe it should go down into the pipe no more that five or six inches.
November 23, 2008 at 7:26 pm #269279benmc
ParticipantRe: Problems with Hotpoint Aquarius 1200 WD62 – Gets Stuck
iadom wrote:If the machine is set directly to spin does the drum revolve and go into spin?
Jim – Thats for the guidance.
I will need to check if the machine spins. I will get over there tomorrow and check the spin cycle.
The plumbing has not been changed or moved as far as I am aware but I will also check tomorrow.
Ben
November 23, 2008 at 7:37 pm #269280benmc
ParticipantQuick Question on the brushes.
If they are worn. How come the drum will turn over to wash but not to spin?
Sorry if this is really stupid but I cannot follow the logic!
Ben
November 23, 2008 at 10:47 pm #269281iadom
It most cases the motor will not run if the brushes are worn, its just that setting the machine to spin is the simplest and quickest way to test the motor and brushes, no fill or heater circuits involved.
I have seen instances were the standpipe has not been secured correctly and has fallen over causing the machine to syphon.
Again, the simplest way to test for syphoning as the cause of the problem would be to place the outlet pipe over the sink if that is possible and see if the machine completes its cycle.
November 24, 2008 at 3:39 pm #269282benmc
ParticipantUPDATE Re Problems Hotpoint Aquarius 1200 WD62 – Gets Stuck
I have an update on the situation.
I have checked the machine and it fills and drains without problems.
When turning to a spin cycle the problems start.
The spin starts but never really gets going. Its as if the drum gets enough energy to get up to speed but then slows down and stops, this takes around 20-30 seconds.
Does this still sound like the brushes?
Thanks again
BenNovember 24, 2008 at 4:36 pm #269283iadom
ModeratorRe: UPDATE: Problems with Hotpoint Aquarius 1200 WD62 Gets S
Sadly if you did this test without any clothes in it then it sounds more like a control timer problem. 😥
I have seen it caused by a sticking pressure switch as well on this model.
TBH, if the brushes were at fault it would be unlikely to cope with a full load of washing on the wash cycle.
November 24, 2008 at 5:37 pm #269284benmc
ParticipantRe: UPDATE: Problems with Hotpoint Aquarius 1200 WD62 Gets S
Jim
Thanks for your help and advice.
The machine is probably now 5-7 years old, so this may well be the time to replace.
Found a BOSCH WAA24162GB for around £230. Looks like a good bet
Ben
November 24, 2008 at 5:47 pm #269285iadom
The pressure switch is only around £15 to £18. Might be worth giving it a go.
Any Bosch at that price will have the dreaded sealed tub. :rolls:
November 24, 2008 at 5:53 pm #269286benmc
Jim – I wish I had the time to ‘fix’ it. The issue is the washing machine is in a rented property and the tenant is currently without a washing machine, so I need a solution quickly.
If the Bosch is not great, what is the current recommendation in the £250-£300 bracket?
Ben
November 24, 2008 at 6:05 pm #269287iadom
Sadly at that price the Bosch is as good as it gets. 😥
A decent machine was £250 to £300 over 25 years ago. 😉
November 24, 2008 at 6:14 pm #269288benmc
The other option is the ISE2 but I cannot find a price or supplier.
or
John Lewis Machine for around £329
BenNovember 24, 2008 at 6:25 pm #269289iadom
The John Lewis will like as not be a Zanussi, not much to chose between that and the Bosch, really depends what sort of warranty you get,the Bosch should include a two year warranty.
November 24, 2008 at 6:26 pm #269290benmc
Any views on the ISE2? I cannot find a price or supplier anywhere!
November 24, 2008 at 6:28 pm #269291iadom
What area are you in?
