Upsizing the size of a hob question.
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Upsizing the size of a hob question.
  • #58041
    Gerard
    We currently have a standard size AEG hob (?60cm).
    Whilst in JL the other day, noticed a Neff hob that is wider but fits a standard aperture. Our hood is a 90 cm hood and their is plenty of space each side of the work top and below is a 120cm wide drawer. If I was to upgrade, should the swap (by a trade person) be quite easy? the current supply is by rigid copper pipe.
    Thanks.
    #333190
    don
    Re: Upsizing the size of a hob question.
    Hi Gerard
    Can you post up the model number of the hob you are considering please and i’ll have a look for you.
    Don
    #333191
    Important points to watch for are :
    The hob top (pan support) should be 760mm fom the cooker hood.
    A isolation valve should also be fitted to the supply (normally behind drawer).
    Any of the units directly above hob shouls also be 760mm.
    Bryan
    #333192
    Gerard
    Thanks Don,
    Since posting, looked at some other designs and quite like the look of this model Fagor 6CFI-5GLSTNAT, not sure how to Hyperlink but here is an address….
    http://www.fagor.co.uk/70cm-burner-gas- … 00094.html
    We have an inbuilt oven and combi microwave from this supplier. It appears that this model also has a “standard 60” type of aperture. The existing hob is an AEG 69802 G.
