Re: urgent help needed with bosch d/w
simon26r wrote:and i have just filled a new module that had a sticky relay were the drain pump would not switch off.
First a sticky drain pump and then a sticky relay from the module that supplies the drain pump? All a bit odd really to be honest?
Can I assume you have checked such things as the insulation on the heater, the water level system etc etc? Your customer states now the machine is still washing and is getting very hot. Could you ask her to stop the machine and check to see if the dispenser lid has released? The dispenser solenoids are a favourite troublespot as well. Is she using the machine on ‘Auto’ setting I wonder?
