UY46X New fan motor needed?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum UY46X New fan motor needed?
  • #72411
    Akurei2000
    I have a hot point UY46X twin cooker and everything seems to be working, except the main oven takes ages to cook food, and does not seem to be heating up as sickly as normal.
    I have removed internal cover at the back and can confirm the element is getting hot, but the fan is not running.
    Would replacing the fan motor assembly help fix this?
    The top oven works fine, and the top fan comes on after grill has been running so I think it must be the bottom oven fan at fault.
    There is a humming, like the motor is trying to run, but no movement in the fan.
    Any help or advice is appreciated.
    #384458
    tj5793
    Re: UY46X New fan motor needed?
    Yes definitely the fan motor needs replacing
    #384459
    Akurei2000
    Many thanks, new fan ordered will report back if successful.
