V. Slim washer/dryer machine?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum V. Slim washer/dryer machine?
  • #8769
    We are a boat-building firm and are currently trying to find a washer/dryer combo machine which is only 480mm in one of either depth or width without exceeding the typical ~850mm height. This is because we need to fit the machine through a 485mm wide aluminium door frame.
    Does anyone know of a model that meets this requirement? Any help would be greatly appreciated.
    many thanks
    Greg Taylor
    #130400
    Re: V. Slim washer/dryer machine?
    Greg,
    A few years back Baumatic supplied such a product, whilst their website shows only the more conventional sizes they may be able to help you?
    http://www.baumatic.co.uk/index.php
    Zanussi also made a shallow depth machine a few years back, but today I think they have given up on that idea, not sure 😕
    don
    I don`t know of a washer dryer but there is the Bosch WFC246C which is only 400mm deep. 1200 spin and a 9kg load and with a two year guarantee. You`re local independant should be able to help.
    Don
    8)
    #130402
    Thanks for your responses. Would matters change any if we were able to squeeze an extra 15mm upto 495mm wide or deep?
    Thanks, Greg
    #130403
    don
    There isn`t anything else that I am aware of in that size range I`m afraid.
    Any chance of gaining the extra space required? The minimum depth in washer dryers I can find is 580mm by Hotpoint.
    Don
    #130404
    What is the smallest washer/dryer available ?
    Paul
    #130405
    don
    Washer dryers are all generally the 60cm square box and 85cm high, Hotpoint make their depth slightly less at 58cm.
    The smallest washing machine I can find is the Zanussi ZWC1300W compact wash load of 3KG, which measures Height 61cm X Width 49.5cm X Depth 51.5cm.
    Don
    #130406
    I had also heard of a slim Zanussi machine but when I saw it I found it was an FL1081, which I would have thought was a full size model. A friend had a very small kitchen and was fitting reduced depth units, worktops etc. If all else fails you may be able to dismantle a new Zanussi and rebuild it inside the boat 😉
    #130407
    don
    Just one more option would be to install a Bosch slimline top loader, granted you would have to “lose” a bit of worktop but the Bosch does have a hinged worktop type outer lid.The controls are on the front like an ordinary front loader.
    Details are Bosch WOP2400 Hieght 85cm X Width 45cm X depth 60cm. 4.5kg load 1200 spin typical water consumption 43 litres but is still only a washing machine with no dryer.
    Hope this helps
    Don
    #130408
    Hi just found this zanussi model
    ZANUSSI Compact Washing Machine Model ZWC1300W
    NOTE: This machine is 24” high by 20” wide and 20” deep. It is about 2/3rds the size of an ordinary washing machine but has all the features of a full size appliance.
    Features
    3kg/6.6lb Wash Load
    Variable Spin
    A: Energy, B: Wash, B: Spin
    16 Programmes
    Delay Timer
    H: 670mm W: 495mm D: 515mm
    Wool Program
    Rinse Hold
    Quickwash
    Variable Temperature
    Bryan :wave:
