Home › Forums › Public Support Forums › Help And Support › Vacuum Cleaner Help Forum › Vacuum for woodburner ash
- This topic has 17 replies, 6 voices, and was last updated 15 years, 4 months ago by
Dustyroad.
November 17, 2010 at 5:44 pm #58938
Dustyroad
ParticipantDoes anyone know if the Numatic cleaners can cope with cleaning the ash from multifuel stoves or, any cleaner that can otherwise cope.
Dustyroad.
November 18, 2010 at 8:51 am #336206kladave
ParticipantRe: Vacuum for woodburner ash
Having our own wood burner we have been faced with the same problems.
Using a bagless machine will burn out the motor on the machine due to the nature of whats getting picked up.We opted for medium sized bag machine and once the machine starts to lose suction replace the paper bag,Infact the vac we use is an old (ish) Electrolux and have been using it for over 8 years.
so any well made bagged vac will do.
No Chinese rubbish!!!November 18, 2010 at 9:08 am #336207Martin
This little guy won’t let you down……………..
November 18, 2010 at 9:15 am #336208don
ModeratorRe: Vacuum for woodburner ash
Sold a couple of Henry’s to a chimney sweep company couple of months ago who reckon it’s the best machine they have ever had.
Don
November 18, 2010 at 1:17 pm #336209Higher-water-level
Sorry everybody but a bagged vac will not do, this is a specialist job 😉 . For this task, especially if there is alot of ash to deal with you would need a special micro-filter/type H hazadous dust vac. Numatic make both.
There are two reasons for this, the filtration system is not strong enough to hold back such a large quantity of dust, which just blows out of the machines exhaust around your room and straight in to your lungs and secondly the machines motor may be damaged by dust getting into the workings.
Type H vacuum cleaner:
http://www.numatic.co.uk/products4.aspx?id=88Micro-filter vacuum cleaner:
http://www.numatic.co.uk/products4.aspx?id=261Both these machines use the standard Numatic filtration (which is excellent BTW) and also on top of that have a HEPA (High Efficiency Particle Arrester) filter to protect the motor and the air you are breathing.
HTH,
Oliver.November 18, 2010 at 2:30 pm #336210Martin
Higher-water-level wrote:Sorry everybody but a bagged vac will not do, this is a specialist job 😉
Hey Oliver! Henry IS Numatic, HENRY has HEPA
Heaven help the poor publican cleaning out his fire grate in the morning. Or the hard grafting chimney sweep that would risk breathing in such harmful pollutants without such invaluable protection from good old HENRY…eh? 😉
November 18, 2010 at 3:18 pm #336211Higher-water-level
Sorry everybody but a bagged vac will not do, this is a specialist job 😉Hey Oliver! Henry IS Numatic, HENRY has HEPA
Hi Martin,
Henry has Hepaflo dust bags, it has not got HEPA filtration. 😉
The Hepaflo bags far more effective than any paper bag, even the good ones, but no Henry has HEPA, there is a microfiltration model called funnily enough Henry Micro, but it has a static charged filter, it is very good but still not strong enough for this type of useage.
Oh aye and I DO know who makes Henrys, I have one me self you know! 😆
Oliver.
November 18, 2010 at 3:34 pm #336212Martin
Higher-water-level wrote:Henry has Hepaflo dust bags, it has not got HEPA filtration. 😉
Oh blimey Oliver I didn’t know that, thanks. I’d better dash across the road and tell the local landlord to beware of potential static discharges when he uses his Henry!
November 18, 2010 at 3:38 pm #336213Higher-water-level
Henry has Hepaflo dust bags, it has not got HEPA filtration. 😉Oh blimey Oliver I didn’t know that, thanks. I’d better dash across the road and tell the local landlord to beware of potential static discharges when he uses his Henry!
:rotl:January 7, 2011 at 9:13 am #336214quickwash
hi all,
I have a multi fuel stove and have minimal amounts of ash from coal as i have an ash pan unlike woodburners. Do you think an ordinary henry or numatic will suffice when i decide to purchase a new vac?
The numatic factory is only 15 miles from me actually 😀
regards
quickwash :plug:
January 7, 2011 at 9:32 am #336215don
Hi quickwash
Happy new year to you 😀
Numatic wrote: Company History
Numatic was founded in 1969 in the Somerset town of Crewkerne, in southwest England, where it produced its first commercial vacuum cleaner design for cleaning coal, oil and gas fired boilers.The Henry is still about the best I can find for that purpose. Sold quite a few to chimney sweeps with no complaints, just make sure that you have a paper bag fitted when cleaning up ash deposits.
HTH 🙂Don
January 7, 2011 at 9:44 am #336216quickwash
Hi Don,
And a very Happy and Prosperous New Year to you 😀
Thanks for you quick reply.
I must confess to very tentatively using my dyson for this job at the moment, takes ages as i do it slowly a bit at a time in the hope of not clogging the motor. Has worked with regular filter washes/changes but obviously i will need to purchase something else soon. I have infact got 2 older seconhand dyson cyclinder style vacs which have coped for over 8 years, so far i hasten to add 😉
best wishes
quickwash :plug:
PS – I was born and bred in crewkerne down here in zomerzet 😀
January 7, 2011 at 11:33 am #336217Higher-water-level
Hi Quickwash,
If it is for minimal amounts only and no more I would suggest you get a Henry Micro (has much finer filtration) and use it with Hepaflo dust bags. A normal Henry is not suitable and the Micro model dosen’t cost much more either.
Oliver 😀
Morning Don :waving: :wave:
January 7, 2011 at 12:02 pm #336218quickwash
hi oliver,
I will look into one of those when i decide to purchase a new vac 😀
thanks
quickwash :plug:
January 7, 2011 at 12:37 pm #336219Martin
quickwash wrote:I have a multi fuel stove and have minimal amounts of ash from coal as i have an ash pan unlike woodburners.
Minimal amounts? Don’t waste your money on another vacuum cleaner then. (You’ve spent enough already with the 1607 and the prospect of a new ISE vented dryer coming up.) So, my advice, for what it’s worth, ashpan deposits spread on your veggie patch ( essential potash for your spuds and runner beans ) Dustpan and brush for any overspill then a quick suck around with your old Dyson and the job’s a good ‘un. 😀
Oh, I almost forgot….Hi Oliver, Hi Don, Hi everybody, Martin here! 😉
