van stock ??
Home Forums General Trade Forum van stock ??
  • #18052
    funkyboogy
    trying build a van stock
    whats the best fast moving stock to keep,
    part no,s please ??
    cheers ally
    ps , ive started with fill/drain hose,s brushes, fridge stats,> brain freeze
    #177529
    Re: van stock ??
    Get all your parts invoices together and they should give you some idea of your recent usage.
    It really depends on the range of appliances and more important the size of your van. 🙂 Trying to give you all the part numbers would be a little difficult to say the least. For instance I carry one Hotpoint WM drum support with me and have another four at home. I can use three or four in a week then none for a week or so, however an engineer working in a hard water area would rarely use one, he may however use far more elements than I do.
    To your short list I would add, door seals, pumps, door interlocks, bearing kits, drum supports, heaters, just for starters.
    It really is all down to experience and proper stock control even if it is all done in your head ( like mine ) 😀
    If I find I am constanly having to order the same part then as long as cost is not an issue I will start to carry it.
    A regular stock taking should identify parts that you have to many of, or are not using as often.
    #177530
    funkyboogy
    Re: van stock ??
    CHEERS FOR REPLY,
    mostly trying to find out if there specific fast moving generic parts,
    #177531
    Re: van stock ??
    every cooker fan element you can get your hands on. I carry 3 crates of them.
