Home › Forums › General Trade Forum › Van stock levels
- This topic has 4 replies, 5 voices, and was last updated 6 years, 10 months ago by
Chris160.
May 23, 2019 at 11:03 pm #95899
Chris160
ParticipantWhat sort of stock do you all carry on the van?
I’m a mobile appliance engineer repairing washers, tumbles and electric ovens. I’m on my own (mobile) with a small van.
Is there a core of carbon brushes, capacitors oven elements etc. that you all carry?
Chris
May 23, 2019 at 11:58 pm #461637electrofix
Moderatorhi Chris welcome to the forums
from my part tend to look at the calls and experience tells you what it might be
as for brushes can only quote qualtex part no car 69 and 72, car 75. car 99 plus car93 bosch brushes plus Beko think car101? are all a must as for caps cap 07 and 08
partly depends on your area as some machines are more common in one area
June 6, 2019 at 6:24 pm #461638crescentapp
ParticipantHi Chris. I run the same as you with just a small van. As electrofix says, experience dictates what you know to carry. As well as the brushes, I carry the commonal Bosch, Beko and Hotpoint pumps. Stuff goes in cycles so over the past 30 years or so, ended up with things I will probably never use again but in their heyday were a weekly fit. I rarely even fit caps now although I’ve got several values on board. I don’t keep many belts now either..appliances rarely seem to last long enough for them to get to a perished state!
June 11, 2019 at 8:47 am #461639pmb
ParticipantYou need a large selection of pumps heaters interlocks drain hoses. Customers are more likely to have job done if you are able the complete the job straight away.
June 11, 2019 at 3:49 pm #461640stratfordgirl
ParticipantAs others have said, I think everyone stocks different things, depending on their customer base, the types of machine they get called out to and the faults they come across.
A lot of the parts needed for washing machines are unfortunately pretty random, motor brushes, heaters, door seals, pumps, belts, dampers, locks, handles, door frames, dispensers, control panel parts, sensors, inverter boards. At least we don’t need to worry so much about drum parts these days!
For tumble dryers, belts, capacitors, tensioners, heaters, sensors, bearings, blowers, mains filters and the occasional power module for good measure.
I don’t repair ovens.
Luckily, a good proportion of repairs don’t need any parts. And of those that do, a fair number you can pre-order the parts based on the fault, eg door seals, door handles. Over the years I’ve learned not to stock anything unless it is for a common fault on a type of machine I still get called out to often. My stock value has pretty much halved over the last few years. Less weight to carry round and much quicker to locate the parts when needed in the van.
