Variable water temperature puzzle – please help!
Home Forums Public Support Forums General Enquiries And Questions Variable water temperature puzzle – please help!
  • #85307
    AEGowner
    Hi, I have just had a new Main multipoint bf boiler fitted to supply hot water only. It seems to work perfectly and there is hot water in all the taps with one exception – the tap in the kitchen which is furthest from the boiler starts cold as expected though soon runs hot but after a few minutes runs cold again, then goes hot again a little while later and so on. The stream of water doesn’t alter in quantity, only in temperature. Is this a problem with the tap, the boiler or pipe length or something else? Our plumber is baffled, so any suggestions would be welcome! Many thanks 🙂
    #428311
    don
    Re: Variable water temperature puzzle – please help!
    Domestic heating is not our forte on these forums, kitchen appliances yes 😀
    I would have thought contacting the manufacturers boiler support would be the way forward. Assuming the install is correct and the installation is to spec you should be okay.
    HTH
    Don
