VAX U89 Power VX2 – switch replacement
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum VAX U89 Power VX2 – switch replacement
  • #79091
    kmjkmj
    Hi – competent engineer-type here, happy to work with things electrical and mechanical, but nervous about pushing/pulling/levering things too hard and snapping them…
    I need to replace the mains switch on a VAX Power VX2 (U89) upright vacuum cleaner. The current switch has become unreliable, and won’t always operate when the button is pushed.
    I’ve undone all the screws I can find, but can’t get to the switch. I suspect it might even be as simple as levering the switch over a bit harder than I have dared to do so far, but…
    Any ideas? (preferably good ones from someone who knows – I have two kids who have been coming up with the daft ones!)
    #407865
    don
    Re: VAX U89 Power VX2 – switch replacement
    If it’s under two years old phone Vax on 0844 412 8455.
    Otherwise can you post up the full model number as there is a good 12 or so models.
    Don
    #407866
    kmjkmj
    Hi Don, thanks. This item is definitely older than 2 years (!)
    The full model number is U89-P2-VX, it’s a VAX POWER VX2.
    Hope this is helpful – I can provide photos if that would help (not quite sure how to do that on this forum, but always willing to try…)
    Cheers
    #407867
    don
    No drawings anywhere which give explosions of that model and no picture of the on off button either.
    If you can’t gain access from the underside then it may be worth looking at the button area to see if it prises out that way.
    HTH 🙂
    Don
    #407868
    kmjkmj
    Thanks Don, I’ll keep trying…
