Vax V-028 Power Jet Pro – Water Valve
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Vax V-028 Power Jet Pro – Water Valve
  • #63240
    Hollytree_Technical
    Hi all
    Does anyone know where I can get a replacement water valve (Part No: 1-9-125987-00) or would someone happen to have one that they would sell to me.
    Thank you
    Jem
    #353062
    Re: Vax V-028 Power Jet Pro – Water Valve
    did try a few of my suppliers all i got was obsolete
    these are a common problem to stick open i think the problem may occur if the unit is not rinsed out with clean water when finished
    you could try lubricating it with a silicon based lubricant and see what happens
    just done same job on my dads but i had one lying around last one i had i am afraid
    Hollytree_Technical
    Unfortunately this one broke when I was testing to see if the water/fluid was reaching that bit so can’t use it again.
    I will keep hoping that some one will have one.
    Jem
    #353064
    typed vax valve in google
    this one for a v026 think it may fit but some had tools water add on some did not
    they are not saying its obsolete may be worth an email
    http://www.espares.co.uk/part/vacuum-cl … oogle+base
    Hollytree_Technical
    Thank you all
    Just thought that I would come back and finish off by saying that I took a risk and ordered one and it is a perfect fit.
    Jem
    #353066
    magic m8
    sorted
