Vented tumble dryer not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Vented tumble dryer not heating
Viewing 15 posts - 1 through 15 (of 17 total)
  • #98209
    Fed
    Hi, I have a Zanussi ZDE47200W vented dryer that runs but doesn’t get warm. After taking the back off I see that the heater element initially gets hot and glows red for a few seconds and then goes cold and stays off.
    I have replaced the heater and the heater Element sensor but the same thing happens.
    any help or suggestions would be appreciated!
    #471364
    what do you call a few seconds ?
    there are thermostats and sensors on the element that cut it out if things get too hot. without the cover in place it will overheat
    with it all back together does it heat in timed mode ?
    Fed
    Hi Dave,
    it’s about 5 to ten seconds. I have put the covers back on and it seems to be the same, although of course I can’t check but it doesn’t heat the drum.
    Grant
    #471366
    Fed
    Sorry, missed the second part of your answer. I don’t think there’s a timed mode, only degrees of dryness on the rotary dial. Am I missing something?
    cheers
    Grant
    #471367
    also most later dryers wont heat unless there are wet clothes in as an energy saving feature which is why i said timed dry as somtimes its exempt
    Fed
    I have been testing it with wet towels in. Do you have any other thoughts?
    Grant
    #471369
    and timed drying ?
    Fed
    I’ll try it when I get home, thanks
    #471371
    Fed
    It doesn’t heat on timed drying
    Regards
    Grant
    #471372
    next then you need to check the front temp sensor
    take off right side its mounted in the fan chamber
    at 20 degrees C you should get a resistance around 6000 ohms
    Fed
    Thanks Dave. Is that a different sensor to the heater element sensor probe as I’ve already replaced that one?
    #471374
    yes different one. senses the air leaving the dryer
    Fed
    Ok thanks, will take a look. Have a good evening.
    #471376
    kaibart
    Just a thought i think there is a thermostat fitted at the front as you open the door the plastic that the door closes into there should be one there this maybe your problem
    #471377
    Fed
    Thanks, I’ll take a look.
    cheers
    Grant
