Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Vestel / Servis FF48148 Temp Sensor?
- This topic has 8 replies, 3 voices, and was last updated 7 years, 2 months ago by
paul_clark.
February 7, 2019 at 12:26 pm #95447
paul_clark
ParticipantHi all. Called out to a friends FF48148 which is running all the time. I grabbed the Vestel circuit diagram, surprise surprise nothing like it. I can see on the PCB PL802 which looks like its the sensor i/p
Down in the guts of the freezer I can only see the cabling for the defrost and fan. The spares listing gives a picture of the sensor which terminates in a 2pin connector and is about 20cm cable length.Is this the correct sensor – and if so where does it hide?! Appreciate any help – my formal qualifications are electronics and normally do the AV equipment / Microwaves and Cookers. Tend not to get involved with these jobs 🙂
Paul
February 7, 2019 at 1:33 pm #460373electrofix
Moderatorhave you checked temperatures?
it will run all the time if it thinks its too warm
February 7, 2019 at 3:12 pm #460374paul_clark
ParticipantFreezers down to -38 and fridge below zero…. yes running 24/7
February 7, 2019 at 3:45 pm #460375kwatt
KeymasterMost all of them, it’s this one:
The modules go as well but not as common I don’t think.
February 7, 2019 at 3:58 pm #460376paul_clark
ParticipantThanks K – that’s what I have in my grubby hand from stock, but for the life of me cannot find where it’s located on the appliance. The module heads off to plug / skt in fridge roof, then the only other bits that are accessible are back of freezer cable tied to the defrost heater – am I simply not looking hard enough?
February 7, 2019 at 4:03 pm #460377electrofix
Moderatorpaul_clark wrote:Freezers down to -38 and fridge below zero…. yes running 24/7
well its not a compressor fault that’s for sure
have you done a resistance test from the board on the sensor ?
February 7, 2019 at 4:29 pm #460378paul_clark
ParticipantFrom memory the cabling at the pcb end was about 4K7 I unplugged all of the connectors in the freezer and the 4k7 remained. As said, I cannot locate this sensor can only find the bimetal switch and thermal fuse. Began to question my sanity and wondered if it was buried in the foam (was it Hotpoint who did that)
February 8, 2019 at 1:29 pm #460379paul_clark
ParticipantVestel response ‘The sensor cannot be changed in that model’ 2 years old built in redundancy….
February 8, 2019 at 2:01 pm #460380electrofix
Moderatormad isn’t it. All they have to do is build in a spare sensor and leave it unplugged
