Anyone familiar with this machine? I can’t find any service info online for less than 50 Euros! I can’t even find a user manual in English.
I have dismantled it and repaired what appears to be a common fault (failure of soldered connections of input connector to speed control PCB) but I have a question about refitting the telescopic handle to the motor unit. Is this handle supposed to lock the operating slider for what looks like a speed control resistor just behind the connector at the handle end of the motor unit? I can’t see any way to insert the handle which would not do this.
I’ve seen a picture online showing use of a separate mains cable straight into the connector on the motor unit, presumably to use it as a cylinder type cleaner with hose attachment instead of the motorised beater head assembly used in upright mode and wonder if that is what this other control is for since the normal control at the handle end is no longer there?
Any ideas?
Cheers
Chris
