Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › VT9 Thermostat Help
- This topic has 6 replies, 3 voices, and was last updated 19 years ago by
jriess11.
April 4, 2007 at 6:54 pm #26383
jriess11
ParticipantHello,
I was wondering if anyone had a spec sheet on the VT9 Universal thermostat. I’m trying to convert a freezer into a refrigerator and am having some trouble getting it to maintain an appropriate temperature range (-1C to 4.5C). Any help would be greatly appreciated.
Thanks,
JoeApril 4, 2007 at 8:11 pm #209913helo_75
ParticipantRe: VT9 Thermostat Help
why on earth would you want to do that?
April 4, 2007 at 8:24 pm #209914jriess11
It was a cheap chest freezer just about the right size to hold a couple of kegs of beer. Frozen beer is not very good though. 😀
April 4, 2007 at 8:59 pm #209915helo_75
i wouldnt think youd ever get that to work if im honest.. not by usin a stat anyway
the only poss way would be to use some sort of timer, to switch it on/off at regular intervals
April 4, 2007 at 9:13 pm #209916jriess11
Why wouldn’t a thermostat work? I’m obviously missing something here.
Thanks for your advice BTW.
April 4, 2007 at 9:39 pm #209917dpm
ParticipantThe average fridge ‘stat will cycle between your setpoint (5c maybe) and a cutoff of perhaps -10c. In a fridge there’s no problem as you’re not putting anything in contact with the coldplate, plus there’s a fair degree of circulation within the chamber.
In a chest freezer however there’s more of a chance of your product touching the cold zone, plus what circulation there is will give you a nice (bleedin cold) region at the bottom.
You’d likely be better getting some kind of cheapo temp. controller that you can program more reasonable hysteresis values into- or go for helo’s timeswitch option.
Some might even say a small circulating fan from a pc might help…There *is* however one stat that might be the job- BC2, as used in wine coolers. According to my info it’s “off” temp varies from +3 to -18, on at 8.5c…
April 4, 2007 at 10:03 pm #209918jriess11
So if I somehow insulate the contents from the cold plate and provide adequate circulation, it could potentially work? I’ll give that a shot and if it fails, take your advice on using the temperature controller. Thanks much!
