Hi I hope someone can help me out with a small problem
I went today to fit a new belt to a Hotpoint VTD 00, all was well untill I came to put the machine back together and noticed that the wires had pulled off the door switch. The switch has position 3, 4, 5 and I have a grey wire that comes from the start switch, a pink and white that comes from the timer and a brown and white that goes down towards the motor/heater. Is there anyone that has a wiring diagram for this machine that could help please
Thanks, Ray.t
To change belt you only need to remove right hand side panel remove console and screw behind console move front panel forward slip belt on replace console and screws stretch belt on with special tool, refit side panel 10 to 15 mins tops.
Thankyou very much johnnyj. This information will get me out of trouble. Thankyou also for the additional information. This will also be of great use to me and I’ll make a note of it for future use.
Thankyou very much once again.
Rayt
