VTD20
  • #49343
    spimps
    Drum scrape on this.is there a mod apart from standing exactly level the cabinet is so weak it gives in all directions.
    #299612
    Re: VTD20
    Apart from the tip the only real cure is the later, modified drum. It has a rounded edge at the back.
    #299613
    Re: VTD20
    An extra washer on the spindle between drum and back panel usually helps.
    #299614
    Re: VTD20
    Its not foolproof, I did a drum shaft repair on one yesterday and fitted an extra washer,three in total and the drum still caught on back if you touched the front of the cabinet. 😥
    #299615
    S1MON
    Change the drum only sure why too cure it
    #299616
    Re: VTD20
    iadom wrote:Apart from the tip the only real cure is the later, modified drum. It has a rounded edge at the back.
    Cough. 😉
    #299617
    gandh1
    Re: VTD20
    iadom wrote:fitted an extra washer,three in total and the drum still caught on back
    Jim this caught my attention because I was led to believe spacing it out with metal washers would end up cutting into the shaft and shortening the life of it unless the washers were nylon? Just wondered if this was genuinely possible?
    Also
    spimps wrote:Drum scrape on this.is there a mod apart from standing exactly level the cabinet is so weak it gives in all directions.
    Was the L-bracket over the heater casing there to stop the rear panel flexing for the precise reason it had the old drum? its just i note the newer dryers with the new drums dont have them
    #299618
    Re: VTD20
    The metal washers will not cut into the shaft, how could they? The only reason the shaft fails is because they did away with the jockey pulleys and substituted the ultra tight stretchy belt which pulls the drum shaft down into the bearing.
    Even the teardrop bearings wear away in no time at all.
    The 1703080 seal & shaft kit actually inlcudes a metal washer.
    A good old Creda design ruined by the bean counters. 👿
    #299619
    washermanuk
    Re: VTD20
    I always fit new front bearings on these that seems to stop it scraping? 😉
    #299620
    twinspark
    Re: VTD20
    drum and rear panel best cure.
    Belts too tight they should go back to pullies and springs 😛
