w/m with no time out on fill !!
Home Forums General Trade Forum w/m with no time out on fill !!
  • #66463
    bzz67
    got a customer with low water pressure. She wants a new machine with 1200 spin and 6kg load. is there a washing machine made today with no time out on fill !!
    i think some modern machines may have flow meters like some dishwashers, would this overcome the problem and which make or model would have this !
    Thanks Barry.
    #364226
    don
    Re: w/m with no time out on fill !!
    Hi Barry
    When it comes to low pressure from wells or bore holes we always use the Bosch machines as they ony require 1 bar minimum pressure. My parents in law until recently ran a Bosch from a well with no problem whatsoever. You will need a flow rate of 8 litres per minute for a Bosch to work correctly.
    Sorry I can’t answer your question directly 😳
    Don
    #364227
    …..also if the machine is taking water from the mains then the local water company are obliged to supply a minimum of 1 bar pressure anyway. Gravity fed supply requires at least a 7 foot head to give a similar flow rate. 9 times out of 10 most makes will cope fine such low pressures.
    As for well water/private supplies then there could be many problems there anyway. So a tub and dolly paddle could be the way forward in cases like that! 😀
    #364228
    As long as it is not one of these No go Bosch
    Changed the inlet valve to no avail. 😥
    #364229
    you can programe a Miele to low pressure mode, not sure how low it will take though.
