Re: w/pool adg642
Hiya,
I’m ex Whirlpool.
Sorry, flow meter is normally 6 flashes changing to 7 flashes.
8 flashes can be a faulty water indicator, could be filter blocked, water foaming giving a false reading,
Syphoning can give this reading.
pot turned over and filled with water, reducing the water level
No stable spray pump working
Is the machine fitted with the Askol pump?
Has the base flooded?
When it starts does it wash ok for a little while and then start pulsing?
Check for syphoning.
HTH
Brian
