w/pool arc6680
  • #48759
    robbo1973
    cust complaining of eratic temps in fridge and E showing in the fridge temp led.i take it this is a fault code on quick inspection it is gassing fine the freezer is fine i did not see the fan run even after closing door and quickly opening it.going back in a couple of days after i looked about for poss fault code.
    any takers?
    cheers chris
    #297669
    robbo1973
    Re: w/pool arc6680
    nobody even got a manual or an idea of fault codes?
    cheers chris
    #297670
    jackster
    Re: w/pool arc6680
    ‘E’ on the display normally signifies a PCB fault, I am sure there is a test programme on these, Ill have a dig and see what I can find. The PCB’s are a common failure on these though.
    #297671
    robbo1973
    Re: w/pool arc6680
    THANKS MATE
    robinsonrobbo1973@yahoo.co.uk
