W/pool AWG349/4 Washer Dryer 8537 3041 5400
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries W/pool AWG349/4 Washer Dryer 8537 3041 5400
  • #53874
    ray.t
    Hi I have one of these washer dryers that is getting too hot on dry and operates the cut out on the thermostat.
    I have reset it and it worked ok for one dry cycle but its gone again now.
    Does anyone know if the thermostat or the ntc is going to be the problem.
    I would change them both but they are not the cheapest @ £41 and £37 each.
    Ray
    #317557
    chezza
    Re: W/pool AWG349/4 Washer Dryer 8537 3041 5400
    is the fan motor ok ? sometimes they can run slow and cause the housing to overheat
    #317558
    ray.t
    Hi, Yeah the fan runs fine. I left it on dry for a while and the heater element had constant power so I think its thermostat/ntc related.
    Ray
    #317559
    boggoff
    air way proberly blocked ,check hose into tub
    #317560
    ray.t
    Hi I did check the hoses all seem to be clear.
    I think I will just have to try the resetable stat first and see how I go.
    Cheers
    Ray
