Lights are on m/c wont start.Tried the start switch thats OK.Brown wires going everywhere and its in a tight spot I could only get at it by turning it on its side as its stacked on top of a washer.I could test the circuit from the timer(hopefully).Strip down and reassembly-then order the part and then repeat is going to be a real pain in this case.Sorry but I’ve no Fax machine.
Hi there is power getting to motor? problem sounds like over temp cutout in motor, check between controller terminal 10 or 11 and neutral which will tell you if power is flowing through motor. I will get wiring diagram sorted out for you tomorow friday.
