Service number 854274015750
Not been to this yet.
The customer says the start light is flashing seven times in a sequence.
The book tells me it is flow meter failure.
I put the part description and machine model number into Connect as a
keyword search and it comes up with the plastic water metering tank
that fits on the side of the machine.
Is the flow meter inside the tank?
Does this error code identify the flow meter as definitely the problem or
could something else associated give this code also?
Laurence
