W/POOL DRYER
  • #11675
    dopper
    AWZ650 W/POOL DRYER NO HEAT, CHECKED BOTH STATS ON HEATER + HEATER IS OK.
    NO POWER TO STATS OR HEATER THING ITS THE TIMER.
    OR IS THERE ANY MORE STATS ON THIS MODEL
    CHEERS PAUL
    #146216
    bazza500
    Re: W/POOL DRYER
    Can`t find that model unless the 9 should be a 0. But there`s a drum outlet stat at the front bottom of this dryer hope this helps.
    #146217
    dopper
    Re: W/POOL DRYER
    SHOULD BE AWZ650
    #146218
    bazza500
    Re: W/POOL DRYER
    In that case if it is the exhaust stat the part no. is 481228208008
    #146219
    simonb
    Re: W/POOL DRYER
    if its the one im thinking of(vented model) the stat in question can be reached from the rear remove back cover and look in at the base of machine 2 screws hold it inplace stat facing downwards into duct. iv had a few open circuit.
    simonb
