Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › W/Pool/Ikea/Smeg DWF416
- This topic has 8 replies, 5 voices, and was last updated 19 years, 7 months ago by
goosegreen.
September 9, 2006 at 6:55 am #20705
goosegreen
ParticipantWhen starting any prog, Will fill, and then wash for exactly 2 mins then goes dead. Have fitted new dispensor coil,and drain pump but its got me stumped. Am now thinking PCB, But have never seen this fault before.
Regards
Goose
September 9, 2006 at 8:15 am #188097Bill
ParticipantRe: W/Pool/Ikea/Smeg DWF416
Goose,
You do not say what make! if SMEG what age? check the break on right hand side also check water pressure going into break.
Bill Ellis :scot:
September 9, 2006 at 11:49 am #188098DentedPorsche
It’s a Whirlpool, dolphin range machine.
Never had this sort of problem before.
No error code?
Have you ran the test program?
W/pool training we were told no error code is a faulty module. (Don’t believe that’s 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} true though).
If you leave the machine when it stops does it go through and complete the cycle (without wash pump running)?Brian
September 9, 2006 at 1:51 pm #188099goosegreen
The machine is about 2 years old and the 85 No is:854585615600 but its definitely a Smeg. I know it crazy! Whirlpool branded, Made for Ikea but manufactured by Smeg 😕
Goose
September 10, 2006 at 8:52 am #188100DentedPorsche
Ah, my Sios disc isn’t new enough for that 12nc. Sorry.
Brian
September 10, 2006 at 9:06 am #188101goosegreen
I should have added that its a 45cm Fully intergrated model.
Goose
September 11, 2006 at 7:46 pm #188102eastlmark
ModeratorRe: W/Pool/Ikea/Smeg DWF416
when you say “dead” do you mean no lights even? No error code then? what about feed to the circ pump? Its not cutting out due to a toc clicking out within the pump?
It is a SMEG model.September 12, 2006 at 6:50 am #188103goosegreen
Hi Eastlemark
The lights stay on the prog selected, Could be motor I am calling back later this week so will check.Goose
September 13, 2006 at 4:38 pm #188104Seamy
Smeg Tech guys told me motor start caps & soap dispenser coils throw up strange faults on these machines, or cable connections to said parts.
