Awg338 (853733815120) Had a look at this one this morning. Fault reported was no spin. Turns no problem on wash but at the point of spinning it aborts (after the briefest increase in speed) and carries on tumbling gently.Filter full so cleaned.draining no problem.pr tube clear.Pr sw seems ok :rolls: Did not have another.Could this be the pr sw not resetting after drain.Dont have much experiance with these.Any advice appreciated.Paul
Sounds like it might aborting the spin as the module is detecting an out of balanced load. Does it spin ok without a load? If it does, then the oob is your problem. Sometimes simply replacing the belt can cure it.
