went to a customer to find there was no water going into the machine
the door is locking i tested for power to the valves could not get a reading but not sure if u can get a reading i also checked the board for damage found none.
any suggestions would be great cheers.
Hi, is this the Indesit W123UK? if it is, may well be motor/brushes gone, the prog will be accepted, the door will lock but nothing more ie. no fill, have you tried just a spin prog to check the motor?
hotpnt wrote:Hi, is this the Indesit W123UK? if it is, may well be motor/brushes gone, the prog will be accepted, the door will lock but nothing more ie. no fill, have you tried just a spin prog to check the motor?
