W256W fitting front plate
  • #79592
    Alanj
    Hi guys, any one got any tips when fitting front plate to above ISE10?
    I had to remove the front plate and remove drum to refit a drum spider screw and had a terrible time trying to fit the two piece front plate and the clamp band.
    Do you remove the band completely to get the two pieces centred properly? How do you then hold everything in place whilst you try to fit band?
    Alan
    #409928
    Allsorts
    Re: W256W fitting front plate
    We found it better top remove the weights and tilt the machine on 45 degs to do it
    #409929
    Alanj
    Having had to return because of slight leak at door, I layed the machine on its back.
    It was much easier to centre the front plates.
    Alan
