hi so i turned knob to a programme held start for 3 sec let go start turned knob to 11 o clock which is the 30 wash on left side then off, tried with motor plug in and out no joy so does that mean the board is gone ? doing my head in now !anyone advise anymore
dop
Thinking about it I don’t think this model needs or even has a ‘reset’ requirement. So, can I ask what the problem actually is? Presumably you’ve replaced worn brushes but the machine still won’t work?
dopper wrote:yes carbons right down new ones fitted all it does now is the rinse light flashing ???
Too bad you didn’t explain that earlier as we could have sussed it back then! 😉
It’s definately a motor fault, so time to check motor circuit especially the TOC on the brush ring. Also check the motor plug and its connection lead right up to the module.
