wae 24363gb Three Beeps ?
  • #52066
    neilsukwg
    Anyone help with this Bosch washer
    Door not locking machine emits 3 beeps and :55 shows up.
    Have tried interlock.
    Any ideas?
    #310491
    nomadPaul
    does the :55 show up because thats the time of the selected cycle ?
    The 3 beeps i’m sure is a door lock problem…..do you get exactly the same connditions/beeps if you try and start the appliance with the door open ?
    I’d re-check that door lock and also the hook on the door to make sure that its engaging properly.
    #310492
    neilsukwg
    Re: wae 24363gb Three Beeps ?
    Thanks Paul
    The :55 shows up no matter looks where I set the program, it looks like a time countdown rather than a fault code.
    Shouldnt the time clear as soon as the dial is moved and not revert back to 55?
    #310493
    nomadPaul
    It should always change the time to coincide whichever programme is selected on the dial. Strange if it isn’t changing from :55.
    Have you checked for any earth faults on heater etc ?
    #310494
    neilsukwg
    No, I will give machine a thorough check over,
    was a bit rushed today, never been so busy, booking 15 jobs a day 2 or 3 days in advance at the moment 😯
    Thanks for your help. Will post back when I cracked it.
