WAE24162UK/Constant fill
  • #46340
    spimps
    Attended this machine a couple of months ago when it was bouncing the fill valve in during wash/heating process.No earth faults but cleaned up comm and this cured problem.
    It’s now returned and fills constantlywith drain pump running as soon as the door locks,seems like board,any thoughts please?
    #288978
    Re: WAE24162UK/Constant fill
    Anti-flood kicked in on the Pressure Switch maybe?
    #288979
    spimps
    Martin wrote:Anti-flood kicked in on the Pressure Switch maybe?
    I’ve checked the diaphragm side of the pressure switch which I presume is the normal fill level which is OK.However the other smaller wires going to the pressure switch,the contacts are o/c but do not close when the the air tube is pressureised.
    Is this pressure switch a simple pressure device or is fine wired side of it different?
    CheersBG
    #288980
    spimps wrote:Is this pressure switch a simple pressure device or is fine wired side of it different?
    I have no idea but when I first saw one of the pressure switches I made the assumption it incorporated an anti-flood sensor. Well that’s what it looks like anyway?
    They only cost £11 so may be worth sticking a new one in to see what happens?
    #288981
    spimps
    When you pressureise the tube there is only one click which operates what is the “normal” part so the other side is a bit of a mystery,it’s likely carrying a low voltage which would energise the pump relay ,might try one at that price though.The machine was scrapped so I got hold of it to try and get to the bottom of it.
    #288982
    spimps wrote:The machine was scrapped so I got hold of it to try and get to the bottom of it.
    Do let us know when you get it sorted then.:tup:
