WAN24100GB/25 small water leak bottom right of machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum WAN24100GB/25 small water leak bottom right of machine
  • #103067
    Tally100
    I get a small water leak about 5cm wide when using the machine any ideas please. bottom right of washer under the part where you can clean out the waste.
    #491681
    It could be anything really, the only way is to get into it and see if you can see where it’s leaking from.
    Tally100
    I have a dryer stacked on top , I take it the engineer won’t help unstack washer/dryer
    #491683
    Most will so long as it’s not abnormal.
    kaibart
    Possibly a hole in the sump hose by what your explaining
    #491685
    DirtyLinen
    Have you done the obvious and checked that the drain hose and pump cap are fully closed?
    #491686
    MarkTaylor
    Water leaks in appliances can be as unpredictable as a night at the casino—sometimes you win, sometimes you don’t. Speaking of unpredictability, if you enjoy gambling as much as I do, exploring options like foreign online casinos can be exciting. For those interested, this site provides some great recommendations: https://gambleorb.com/best-foreign-online-casinos/ – much like fixing a leak, finding the right platform is all about making smart choices!
